How do you factory default the MSE 3350 Mobility Solution Engine
Sep 15th, 2008
Hi Guys
I was wondering if anyone knows how to factory default the MSE or know of a way to enable the setup wizard again.
Is there a way to check the status or change the WCS communication password manually.
Thanks in advanced
bbxie Mon, 09/15/2008 - 15:13
You can use following steps to restore factory default fo MSE:
Step 1 In Cisco WCS, click Mobility > Mobility Service Engines.
Step 2 Click the name of the mobility services engine you want to configure.
Step 3 Click System (left panel).
Step 4 Click Advanced Parameters.
Step 5 In the Advanced Commands section (right), click Clear Configuration.
Step 6Click OK to clear the mobility services engine configurations.
Scott Fella Mon, 09/15/2008 - 17:54
You can also run this from the cli to get the startup wizard:
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
