Welcome to the Community!
The Community is a hub for connecting with your peers and Cisco specialists to ask for help, share your expertise, build your network, and grow professionally.
New Here? Click here to learn more and get started.
1928790members
1242588discussions
Community Activity
Resolved! SVI and Subinterface Ingress/Egress Unicast Counters
Hi,We migrated from Catalyst 6500 to Nexus 93180YC-FX3 core switches in vPC configuration running NXOS 10.2.4. What I miss in the SNMP monitoring are the traffic counters for the VLAN interfaces. I found the following in the Nexus 9000 configuration ...
Resolved! Cisco Firepower 2130 - no console access
I have a couple of Cisco Firepowers that I can access thru SSH or the FDM, but I can't console to them?-Software version: 7.0.5-72-Configured with primary and secondary-Base license-Not using FMCCan someone tell me how to get console access? Thank yo...
DSterling by Level 1
  • 202 Views
  • 7 replies
IP routing using domain
The host for my current server (Windows Hyper-V machine with four or five VMs) that handles my email and web sites is going away. I'm planning on moving that physical server to my house and using DDNS to route that traffic in. Realize this is very lo...
Dual ISP connection gi0/2 not able to connect to internet
Hello,I need your help - currently we have a  2921 Cisco router connected to dual ISPs using "gi0/0 & gi0/1" and we are able to connect to either ISP successfully.  Once we connect gi0/2 to any device the connected switch is not able to access the in...
dgrant524 by Level 1
  • 52 Views
  • 4 replies
The operation took longer than expected.
I have just synchronized both Active Directory and Cisco ISE, ISE is using my server (AD) as an NTP server, everything is fine, but now I'm facing an issue "Status Summary: The operation took longer than expected. This may be caused by slow network c...
Jason2005 by Level 1
  • 6 Views
  • 0 replies
Supervisor engines configured for redundancy appear as "STANDBY HOT" and "STANDBY COLD" in the output of the show redundancy states command
Core issueRoute Processor Redundancy (RPR) refers to the provision of support for the redundancy feature. In the RPR mode, one of the supervisor engines is active and operational, while the second supervisor engine is in the standby mode. If the acti...
TCC_2 by Level 10
  • 20587 Views
  • 1 replies
Docker network MacVLAN and IPvlan
I have a question that I am not understanding about docker networks, Macvlan and ipvlan. In the first example, I want to show you the macvlan bridge mode network. This works correctly for me, I show you what I have done to make it work correctly.1. F...
Meraki Duo SSO through SAML
I'm tryign to set up Duo SSO for Meraki Client VPN, the knowledgebase seems out of date as it refers to choosing the Applciation Protect page when currently it's meant to use SAML. I have a few items I am not 100% sure where to get1) I think the enti...
CDragna by Level 1
  • 36 Views
  • 0 replies
Resolved! How to download crashinfo file?
Hey guys,I would like to know about downloading crashinfo file from the flash drive.Pls see below:RSW01#dirDirectory of flash:/ 2 -rwx 5708466 Feb 28 1993 19:57:48 -06:00 c2960-lanbasek9-mz.122-35.SE.bin 3 -rwx 1048 May 16 2008 ...
Cisco ISE integration with SCCM
Hi While Integrating ISE with SCCM 2012 based on below link, i am getting error related to DCOMhttps://community.cisco.com/t5/security-knowledge-base/how-to-integrate-cisco-ise-with-microsoft-sccm-for-patch/ta-p/3725035 Do any one having solution on ...
