Router as AAA for wireless
Sep 15th, 2008
Hi I'm trying to set up EAP as the authentication method in an autonomous AP deployment. For this I need to define an radius server, but I don't have a specific radius server. I have an 1841 router with advanced security, can I use this as the radius SERVER ? If so, can you please guide me to the correct way of doing it ?
Many thanks
thedinuka Mon, 09/15/2008 - 19:58
hi
thanks, but there is a prob. You can only define 50 users in this way. But I need around 100.
Also, whats wrong with using LEAP or EAP-FAST ?
