1841 as Radius Server?
Sep 15th, 2008
Hi I'm trying to set up EAP as the authentication method in an autonomous AP deployment. For this I need to define an radius server, but I don't have a specific radius server. I have an 1841 router with advanced security, can I use this as the radius SERVER ? If so, can you please guide me to the correct way of doing it ?
Many thanks
Collin Clark Mon, 09/15/2008 - 12:01
  • Purple, 4500 points or more
AFAIK, no. You can use Microsoft IAS or if you use Linux, freeradius.
Hope that helps.
thedinuka Mon, 09/15/2008 - 18:42
hi
thanks. Can I do it in an ASA ? sya ASA5505 or 5510
Din
