ASA replacing a 3030 VPN concentrator
Sep 15th, 2008
i have to research replacing an existing 3030 with a 5540 ASA and i'm looking for a config guide
i've had a look in the asa config guides but can't see what i need - though its probably a case of seeing the trees
can anyone forward e a link or guide which shows how to setup a 5540 as a vpn concentrator (800 vpn users)
thanks to anyone taking the time to respond
Which method of access? Client or SSL? It's fairly easy using the ASDM. CLI is a bit more complex.
Also, how many access-groups? You configure access groups on the ASA just the same as on the 3000 series. Different groups have different ACLs and such. This way you can control them and where and when they can go somewhere.
How will the authorization/authentication be controlled? All local accounts or thru RADIUS?
There's many guides and configuration help under the URL:
Please let us know if there is more we can help with. BTW, you need CCO access to get to the above link.
