Can i setup local authentication on wlc 4402?
Answered Question
Sep 15th, 2008
We are using wlc 4402 and 802.1x peap with accs back to our active directory.
Is there a way that local - (this computer) non domain accounts can still login? Can i make the user locally in the wlc?
how will it work when i try to connect on the windows wireless zero?
Correct Answer by bbxie about 8 years 5 months ago
For non domain accounts to login, you have two options:
1.in ACS you can create a internal user database which will include all the non domain user accounts, so when a user try to access the WLAN, ACS will firstly check internal user database, if not there, ACS will forward it to AD user database to auth through configured unknow user policy.
2. You can use local EAP in WLC, and create local user account in WLC for all the non domain user. WLC will user ACS to auth the user, if can't find, it will use local EAP to auth the user, for detailed configuration guide on configure local EAP, you can refer following link: http://www.cisco.com/en/US/docs/wireless/controller/5.1/configuration/guide/c51sol.html#wp1172157
It doesn't matter if you use windows zero config or use special client wireless software.
Overall Rating: 5 (1 ratings)
Correct Answer
bbxie Mon, 09/15/2008 - 15:05
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
