cowetacoit Mon, 09/15/2008 - 12:13
Gnutella jumps ports so no way to block it unless i spend $$ on web filter.
I would perform a detailed packet capture in the Gnutella application session - and see if there is anything that identifies it uniquely at the application level.
or if you have a router that supports NBAR - block the gnutella traffic using the specific PLDM - or you can write your own specific apps to block in NABR.
HTH>
lucamotta Tue, 09/30/2008 - 07:02
I configured as it says, but p2p continues to work. If i check "Check for Protocol violation" , P2P doesn't work as also POP3 and some http site.
Any solution? I think we have to install WebFilter.
right?
bye bye
