PBX to Gateway Integration - Caller ID
Sep 15th, 2008
If we a PRI from telco that connects into a cisco gateway, then also attached to the cisco gateway we connect to a legacy PBX (via bak to back PRI connection but no Qsig) will the caller ID (number and/or name) be able to be extended to the PBX? We're also connnecting to a CME via this gateway but want to ensure that caller ID can get to PBX.
thanks in advance
Anonymous (not verified) Fri, 09/19/2008 - 10:24
The Cisco Unity IP Media Gateway products are integration devices designed to offer a connection between Cisco Unity or Cisco Unity Connection servers and your existing traditional private branch exchange (PBX) so caller ID can be extended to the PBX.
sameh.hasan Wed, 04/01/2009 - 02:08
does PIMG limited for some countries , can i use it here in Egypt ??
