Upgrade Cisco DMA from 5.0(4) to 6.1(2)
Sep 15th, 2008
I am planning to upgrade CCM from ver 4.1(3) to 6.1(2). When I try to install Cisco DMA 6.1(2) , I received message that another version install on the server.
I checked that on the publisher instaled Cisco DMA 5.0(4) .
When I try uninstall version I received message Error: 1720
How can I unstall previos version of DMA 5.0(4)
Overall Rating: 5 (1 ratings)
gogasca Mon, 09/15/2008 - 22:54
  • Green, 3000 points or more
Error 1720. There is a problem with this Windows Installer
package. A script required for this install to complete could
not be run. Contact your support personel or package vendor.
Please check that you are following correct steps:
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/dma/5_0_x/dmaug504.html#wp37966
If so check:
http://tools.cisco.com/Support/BugToolKit/search/getBugDetails.do?method=fetchBugDetails&bugId=CSCsk56504
vpergament Tue, 09/16/2008 - 09:32
Gonzalo,
Thank you very much after I rename dll file I can uninstall old version of DMA 5.0(4) and install new one 6.1(2)
