Prefix versus Access-list when distributing routes
Sep 15th, 2008
When advertising/distributing/redistributing routes, is there a general rule of thumb as to when to use an access-list and when to use a prefix-list?
Edison Ortiz Mon, 09/15/2008 - 15:57
  • Hall of Fame,
    Founding Member
It depends on the requirements, if you are asked to deny/permit odd/even networks, then ip access-list is the tool to use.
If you are asked to deny/permit a range of networks you have more flexibility with ip prefix-list
For instance,
ip prefix-list NETPRO deny 10.0.0.0/8 ge 25
This ip prefix list is configured to deny routes from the 10.0.0.0/8 network that have a mask length that is greater than or equal to 25 bits
Kind of hard to do the same while using ip access-list
Know both tools and you make the case which one to use more effectively. I've also read ip prefix-list are processed faster by the hardware.
HTH,
__
Edison.
