Static NAT based on destination subnet
Sep 15th, 2008
I need a Cisco 1841 router to perform Static NAT only for a given remote destination.
For example, we have
Site A
Site B
Site C
Site A <==> Site B <==> Site C
When Site A talks to Site B I don't need a NAT translation. But when Site A talks to Site C, I need the router at Site B to NAT to When Site C talks to I need it to NAT to
I've been able to get it to work using route-maps and dynamic NAT pools, but it's not the way I need it. For example, is being NATTED to instead of and the return traffic isn't making it back.
I sure hope this makes sense.
Overall Rating: 4 (1 ratings)
Marwan ALshawi Mon, 09/15/2008 - 17:09
try this on router B:
access-list 100 permit
route-map nat1 permit 10
match ip address 100
ip nat inside source static route-map nat1
and apply ip nat inside on the interface facing site A and ip nat outside on the interface faceing site C
and have a look at the following link as well:
good luck
if helpful Rate
dennylester Tue, 09/16/2008 - 07:56
This kind of worked. The IP Nat inside source static only did a one to one translation.
I need
ip nat inside source static network /24
but it won't let me reference a route-map. I suppose I can manually create 254 one to one translations.
jpoplawski Tue, 09/16/2008 - 14:35
Can I ask why the need for NAT? It seems like you should just be able to turn on ospf or eigrp and route the traffic accordingly? I don't want to oversimplify, however doing a one to one nat for 254 hosts, sounds pretty cumbersome.
dennylester Tue, 09/16/2008 - 14:52
Overlapping subnets.
Site C bought us out and assigned us a block of private addresses. We haven't renumbered Site A yet but need the connectivity right away. Somewhere on the Site C network they have an overlap and mandated we change our end.
Since Site B was ours to begin with, all their hosts are currently configured to access Site A resources on the old subnet.
The good news is the one to one configuration went pretty quick using Excel and notepad and pasting the configuration into the router.
