AbbrDial for all users
Sep 15th, 2008
Is there a way to create a list of AbbrDial's and make is accessable on all phones? Today we have route patterns that all users can dial, which is used as a Corporate speed dial list. We just brought our first branch office online and if a branch users dials one of the route patterns that call would go out the corporate office and we would like it to go out the branch office PRI. So it looks like the AbbrDial might be the best option if we can load them for all phones.
Jaime Valencia Mon, 09/15/2008 - 18:36
only option is to export phones using all details, add the numbers in the CSV file. delete phones and reinsert them
java
if this helps, please rate
kkoeper12 Thu, 03/05/2009 - 12:45
Best bet would be to have branch offices in a different partition then create a translation patern for that partition. Each site could even use the same Corporate speed dial numbers but you could send it out the local PRI.
James Hawkins Mon, 04/13/2009 - 02:35
If you are running CUCM7 then the using Local Route Group as the destination for route patterns would route the calls out of the local gateways.
