Using VMware for Voice Lab
Chuck Reid
I am interested in using VMware to set up a voice lab and I have a few questions:
1) Should I use VMware workstation or VMware server, I have both available.
2) Is it possible to run more than 2 virtual machines at a time on a typical PC Server? Whats the limiting factor, memory or cpu cycles?
3) My goal is to get 4-6 virtual servers online and networked to do testing/training, CM/IPCC/Presence/Unity, how many PC style servers would I realistically need to do this? Any suggestion platform?
4) What about licensing, does Cisco have demo/learning/lab licenses availble that engineers can purchase?
Thanks for any info!
Chuck
Hi Chuck,
Sorry for the delay (I never saw the follow-up question)
The software for a Unity demonstration system can be ordered on line. The orderable demonstration system is the easiest way to get an entire set of the discs, including third-party software (except Windows 2000 Server). It is available at https://tools.cisco.com/qtc/config/jsp/configureHome.jsp. The part number is UNITY4-DEMO-10USR.
Here is the related Unity 5.x info;
A demonstration system uses one of two different license files:
•Default license file (available on the Cisco Unity server).
•Time-limited license file (must be ordered from Cisco).
Limits on a Cisco Unity Demonstration System
Depending on the type of license file you use-Default License File or Time-Limited License File-the Cisco Unity demonstration system will have the limits listed below.
10 languages
2 RealSpeak text-to-speech (TTS) sessions
10 mailboxes for one of the following subscriber types:
-Unified Messaging (UM) subscribers
-Voice Messaging (VM) subscribers
10 Cisco Unity Inbox subscribers
2 voice ports
2 voice-recognition sessions
30-second limit for messages
The ability to integrate with any supported phone system
The time-limited license enables either Unified Messaging (UM) or Voice Messaging (VM) with the following limitations:
UM feature package
-50 UM subscribers with 16 sessions
-2 RealSpeak text-to-speech (TTS) sessions
-2 languages
-AMIS
-16 voice ports
-2 voice-recognition sessions
VM feature package
-50 VM subscribers with 16 sessions
-2 languages
-25 Cisco Unity Inbox users
-16 voice ports
The time-limited license includes the following additional limitations:
Time limit (after which Cisco Unity stops handling calls)
-60 days
-90 days
Only one license file on the Cisco Unity server is permitted
Non-renewable
Locked to the specific MAC address of the network interface card (NIC) on the Cisco Unity server
From this good doc;
http://www.cisco.com/en/US/docs/voice_ip_comm/unity/5x/release/notes/501curelnotes.html#wp42815
Hope this helps!
Rob
10 Replies 10
Marwan ALshawi
1) both works
2) u can run as much as u want.. but this will need more RAM and CPU as well
for two VM u need at leat 1.5 to 2 G og RAM !!
3)if u have a server with high qualifications like ram and cpu u can run it
4) i think there is a lab testing licensing not sure
if helpful Rate
As per previous comments, any high spec PC/server will do for this.
Personally I run VMWare workstation 6 for each of these servers:
SQL
CCM6
TTS & ASR
UCCX 5.0
They work fine on a standard PC (2GHz) plus 4GB of RAM but would work even better on a dual/quad core machine with double the RAM!
You can then install IPC's and Dynamips etc. to extend the lab if needed.
Please rate useful posts...
Chuck Reid
So, can anyone talk more about licensing for a home lab, I havn't run across anything yet.
If I have a quad core PC server with 4 gig ram I should be able to run 4 Vm servers at the same time?
Chuck
Hi Chuck,
Yeah, the PC should be fine running 4 VM's.
You will have to source your own licenses for the CallManagers and UCCX etc, but certain websites have pre-configured VMWare's which you can use...
If you know of any of these websites, let me know.
Chuck
Try this one Chuck. You will have to register but the forums are particularly useful and it's possible to obtain a wide variety of things including study material etc.
http://www.sadikhov.com/
Rob Huffman
Hi Chuck,
Just to add a note to the great info from Marwan and Tim, here is the related info for CCM;
Cisco Unified Communications Manager 6.0 SDK.
Part#: CM6.0-K9-SDK=
The Cisco Unified Communications Manager 6.0 SDK is a developer version of Unified Communications Manager made available strictly for development and test use only - not for production use. The software comes with a 50-DLU license and must be installed for use on a computer running the VMWare Player, which is available as a free download.
The Cisco Unified Communications Manager 6.0 SDK is a developer version of Unified Communications Manager made available strictly for development and test use only - not for production use. This software is available to all developers interested in creating applications for the Cisco Unified Communications system of voice, video, and IP communications products. The software comes with a 50-DLU license and must be installed for use on a computer running the VMWare Player, which is available as a free download.
https://cisco.mediuscorp.com/market/callmanager/productView.se.work;jsessionid=7030801ef9d5$C4$FD$C?/nxt/rcrs/proieidentity/=16340
To purchase this developer version of Cisco Unified Communications Manager 6.0, please use the link below to go to the Cisco Marketplace page for this SDK product. You will need a credit card to purchase this product.
Cisco Marketplace
http://www.cisco.com/web/developer/cucm/content/download.html
Hope this helps!
Rob
Thanks Rob,
Is there a similar SDK available for IPCCX/Unity/Presence etc...?
Thansk again!
For IPCCX
No SDK avilable ,Let me check for unity /presence
Hi Chuck,
10 languages
2 voice ports
UM feature package
-2 languages
-AMIS
-16 voice ports
VM feature package
-2 languages
-16 voice ports
-60 days
-90 days
Non-renewable
From this good doc;
Hope this helps!
Rob
