Configure 7914 expansion module in CCME
Sep 15th, 2008
what are the configurations required for adding 7914 expansion module in CCME.
A template would be highly appreciated.
Overall Rating: 4 (1 ratings)
Marwan ALshawi Mon, 09/15/2008 - 22:05
The following example defines the IP phone with phone-tag 10 as a Cisco Unified IP Phone 7960G with 2 attached Cisco Unified IP Phone 7914 Expansion Modules:
Router(config)# ephone 10
Router(config-ephone)# type 7960 addon 1 7914 2 7914
if helpful Rate
anwar-ahmed Wed, 09/24/2008 - 14:22
I have 7960 with 7914 expension module and it is working but some time it does not work and retype command under ephone is required.
After retype "type" command it works again for while.
Thanks in advance
slongewa Thu, 09/25/2008 - 13:34
anwar -
I've been having the identical problem with a UC520 and haven't been able to figure out what is causing it yet. If I come up with something, I'll definitely let you know.
anwar-ahmed Mon, 10/06/2008 - 06:53
Thanks Steve
Right now I configire Type command whenever reboot cme.
Anwar Ahmed
