IPSEC --> Phase 1 not comming up.
Sep 15th, 2008
I am trying to create an IPSEC but currently is not able to get the ISAKMP phase up. I have checked the keys and it is OK.
debug output**********
*Mar 4 07:02:43.373: ISAKMP: Error while processing SA request: Failed to initi
alize SA
*Mar 4 07:02:43.373: ISAKMP: Error while processing KMI message 0, error 2.
pbkk1093#
*Mar 4 07:03:13.833: ISAKMP:(2010):deleting SA reason "Death by retransmission
P1" state (I) MM_KEY_EXCH (peer 57.72.23.75)
*Mar 4 07:03:58.373: ISAKMP: Error while processing SA request: Failed to initi
alize SA
*Mar 4 07:05:58.373: ISAKMP:(0): SA request profile is (NULL)
*Mar 4 07:05:58.373: ISAKMP: Created a peer struct for 57.72.23.75, peer port 5
*Mar 4 07:05:58.373: ISAKMP: local port 500, remote port 500
*Mar 4 07:05:58.373: ISAKMP: set new node 0 to QM_IDLE
*Mar 4 07:05:58.373: ISAKMP: Find a dup sa in thdebug crypto isakmp e avl tree
during calling isadb_insert sa = 83F0BB84
*Mar 4 07:05:58.373: ISAKMP:(0):Can not start Aggressive mode, trying Main mode
*Mar 4 07:05:58.373: ISAKMP:(0):found peer pre-shared key matching 57.72.23.75
*Mar 4 07:05:58.373: ISAKMP:(0):Input = IKE_MESG_FROM_IPSEC, IKE_SA_REQ_MM
*Mar 4 07:05:58.373: ISAKMP:(0):Old State = IKE_READY New State = IKE_I_MM1
*Mar 4 07:05:58.373: ISAKMP:(0): beginning Main Mode exchange
*Mar 4 07:05:58.373: ISAKMP:(0): sending packet to 57.72.23.75 my_port 500 peer
_port 500 (I) MM_NO_STATE
*Mar 4 07:05:59.133: ISAKMP (0:0): received packet from 57.72.23.75 dport 500 s
port 500 Global (I) MM_NO_STATE
*Mar 4 07:05:59.133: ISAKMP:(0):Input = IKE_MESG_FROM_PEER, IKE_MM_EXCH
*Mar 4 07:05:59.133: ISAKMP:(0):Old State = IKE_I_MM1 New State = IKE_I_MM2
*Mar 4 07:05:59.133: ISAKMP:(0): processing SA payload. message ID = 0
*Mar 4 07:05:59.133: ISAKMP:(0): processing vendor id payload
*Mar 4 07:05:59.133: ISAKMP:(0): vendor ID seems Unity/DPD but major 157 mismat
*Mar 4 07:05:59.137: ISAKMP: encryption 3DES-CBC
*Mar 4 07:05:59.137: ISAKMP: default group 1
*Mar 4 07:05:59.137: ISAKMP: auth pre-share
*Mar 4 07:05:59.137: ISAKMP: life type in seconds
*Mar 4 07:05:59.137: ISAKMP: life duration (basic) of 28800
*Mar 4 07:05:59.137: ISAKMP:(0):atts are acceptable. Next payload is 0
*Mar 4 07:05:59.137: ISAKMP:(0): processing vendor id payload
*Mar 4 07:05:59.137: ISAKMP:(0): vendor ID seems Unity/DPD but major 157 mismat
*Mar 4 07:05:59.137: ISAKMP:(0):Old State = IKE_I_MM2 New State = IKE_I_MM2
*Mar 4 07:05:59.137: ISAKMP:(0): sending packet to 57.72.23.75 my_port 500 peer
_port 500 (I) MM_SA_SETUP
*Mar 4 07:05:59.137: ISAKMP:(0):Input = IKE_MESG_INTERNAL, IKE_PROCESS_COMPLETE
*Mar 4 07:05:59.137: ISAKMP:(0):Old State = IKE_I_MM2 New State = IKE_I_MM3
*Mar 4 07:05:59.369: ISAKMP (0:0): received packet from 57.72.23.75 dport 500 s
port 500 Global (I) MM_SA_SETUP
*Mar 4 07:05:59.369: ISAKMP:(0):Input = IKE_MESG_FROM_PEER, IKE_MM_EXCH
*Mar 4 07:05:59.369: ISAKMP:(0):Old State = IKE_I_MM3 New State = IKE_I_MM4
*Mar 4 07:05:59.369: ISAKMP:(0): processing KE payload. message ID = 0
*Mar 4 07:05:59.373: ISAKMP:(0): processing NONCE payload. message ID = 0
*Mar 4 07:05:59.373: ISAKMP:(0):found peer pre-shared key matching 57.72.23.75
*Mar 4 07:05:59.373: ISAKMP:(2013): processing vendor id payload
*Mar 4 07:05:59.373: ISAKMP:(2013): vendor ID is Unity
*Mar 4 07:05:59.373: ISAKMP:(2013): vendor ID is DPD
*Mar 4 07:05:59.377: ISAKMP:(2013): speaking to another IOS box!
*Mar 4 07:05:59.377: ISAKMP:received payload type 20
*Mar 4 07:05:59.377: ISAKMP (0:2013): NAT found, the node inside NAT
*Mar 4 07:05:59.377: ISAKMP:(2013):Input = IKE_MESG_INTERNAL, IKE_PROCESS_MAIN_
singhsaju Tue, 09/16/2008 - 12:20
Can you explain your setup ?
Following log indicates NAT in between the devices.":
