Implementing QoS on CallManager Express
Sep 15th, 2008
We are running CallManager Express 4.0.
We are connected to another location using IPLC link.
Please let me know how to implement QoS on CallManager Express so that we can save bandwidth.
Help me out..
Marwan ALshawi Mon, 09/15/2008 - 22:00
the following lik will give the basic setup for CME and it QOS:
then after u have done the marking and trust corectly
on cme
u can make policies for example lets say uh ave corectly marked the voice trafic with dscp EF
class-map voice
match ip dscp ef
class-map call-signaling
match ip precedence cs3
policy-map cme-policy
class voice
priority precent 30
class call-signaling
bandwidth 40
class class-default
then go to the outbound WAN interface
for example
service-policy cme-policy output
the numbers put like 30 or 40 only for example the percent can be replace by a number only
like priority 30 means 30 K
class default mean all other traffic
the class maps abov will use this alocated amount of bandwidth in case of conjistion in case of no conjistion will use whatever bandwidth available
good luck
if helpful Rate
