jaichauh Tue, 09/16/2008 - 05:07
Wisely used, easy to configure and manage:
Cisco 870 Series of integrated services routers are fixed-configuration routers that support multiple types of DSL technologies, broadband cable, and Metro Ethernet connections in small offices.
They provide the performance needed to run concurrent services, including firewall, intrusion prevention, and encryption for VPNs; optional 802.11b/g for WLAN networking; and quality of service (QoS) features for optimizing voice and video applications. In addition, the Cisco Router and Security Device Manager (SDM) Web-based configuration tool simplifies setup and deployment, and centralized management capabilities give network managers visibility and control of the network configurations at the remote site.
Please take a look at the following datasheet:
http://www.cisco.com/en/US/prod/collateral/routers/ps380/ps6200/product_data_sheet0900aecd8028a976.html
rjewelers Tue, 09/16/2008 - 05:14
(I actually read it as widely...) Thanks.
Ok, looked at the Data Sheet. Thank you for the recommendation. I like the 871 and see that it is what I need.
One last question --> What's the difference between the 871 and the 871W? Are they separate models? Should I look at the 871W instead?
rjewelers Tue, 09/16/2008 - 06:40
I believe the CISCO871-K9 is the non-wireless model and CISCO871W-G-A-K9, CISCO871W-G-E-K9, and CISCO871W-G-J-K9 are the wireless models.
Can anyone confirm my assumption. Also, can anyone differentiate between the 'A', 'E', and 'J' variations.
Thank you.
jaichauh Tue, 09/16/2008 - 06:46
yep..
W stands for wireless and G means, it has got a G radio. So, CISCO871W-G is the right model.
A-K9, E-K9, J-K9 are the regulatory domain.
A- American
E-Europe
J-Japan
An american model is CISCO871W-G-A-K9.
-Jai
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
