EIGRP redistribution
Answered Question
Sep 16th, 2008
Hi All!
Basically, there are three routers with EIGRP enabled. Router A is a neighbor to Router B, Router B is a neighbor to Router C. Router A and Router C are not neighbors.
I have noticed, that Router B does not distribute networks learned from Router A to Router C. And vice versa.
What is the problem with configuration?
Thank you in advance
Correct Answer by Richard Burts about 8 years 7 months ago
It looks to me like Paul is on the right track. Quoting from the original post by Fuad:
"Router A is a neighbor to Router B, Router B is a neighbor to Router C. Router A and Router C are not neighbors"
It appears that all three routers are in the same subnet. Normally each router would form a neighbor relationship with all other EIGRP routers in the subnet. It looks like the manual specification of neighbors is preventing the neighbor relationship between router A and router C. router B is not advertising router A routes to router C because it believes that router C should be learning them directly from router A.
Rick
Overall Rating: 5 (1 ratings)
lgijssel Tue, 09/16/2008 - 05:10
  • Red, 2250 points or more
The two pairs may be placed in different AS.
Redistribution between AS' is not automatic.
Please post the output of 'sh ip prot' from router B.
Posting the configs would be helpful too.
Leo
Richard Burts Tue, 09/16/2008 - 05:16
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Fuad
You ask "What is the problem with configuration?" but you do not give us the configuration to analyze. Leo has identified a possible problem. I would add that it might be a problem with auto summarization, or it might be an issue with distribute lists, or it might be something else. Without seeing the configs it is difficult for us to tell what the issue is.
While I agree with Leo that the output of show ip protocol might be helpful (especially if it is an issue with multiple EIGRP AS numbers) I believe that seeing the configs would be the most helpful thing.
Rick
fgasimzade Tue, 09/16/2008 - 05:25
Router B:
Routing Protocol is "eigrp 2007"
Outgoing update filter list for all interfaces is not set
Incoming update filter list for all interfaces is not set
Default networks flagged in outgoing updates
Default networks accepted from incoming updates
EIGRP metric weight K1=1, K2=0, K3=1, K4=0, K5=0
EIGRP maximum hopcount 100
EIGRP maximum metric variance 1
Redistributing: connected, eigrp 2007
EIGRP NSF-aware route hold timer is 240s
EIGRP NSF disabled
NSF signal timer is 20s
NSF converge timer is 120s
Automatic network summarization is not in effect
Maximum path: 4
Routing for Networks:
10.254.252.0/27
192.168.0.0/23
192.168.2.0/23
192.168.15.0
192.168.16.0/23
192.168.18.0/23
192.168.55.0
192.168.100.0
192.168.101.0
192.168.106.0
192.168.139.0
192.168.213.0
192.168.254.0
Routing Information Sources:
Gateway Distance Last Update
192.168.254.2 90 1d03h
192.168.254.1 90 1d03h
192.168.254.10 90 6w3d
192.168.254.11 90 1d03h
192.168.254.48 90 1d11h
192.168.254.38 90 1d03h
192.168.254.46 90 1d03h
192.168.254.70 90 5w1d
Distance: internal 90 external 170
fgasimzade Tue, 09/16/2008 - 05:29
Network 192.168.11.0 is directly connected on Router C.
Network 192.168.22.0 is learned by Router A from another router.
Router B knows everything about both networks. However, router A knows nothing about 192.168.11.0 and router C knows nothing about 192.168.22.0
Richard Burts Tue, 09/16/2008 - 05:37
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Fuad
The output of show ip protocol shows that there is only a single AS number. And it show that auto summarization is turned off - at least on router B. If auto summarization were on for routers A and C it could still be an isse with automatic summarization.
I believe that seeing the configs is even more important. I would also request the output of show ip eigrp topology from A or C (or both)
Rick
fgasimzade Tue, 09/16/2008 - 20:08
Here is iegrp config from Router C:
router eigrp 2007
redistribute connected
network 192.168.11.0
network 192.168.12.0
network 192.168.254.0
neighbor 192.168.254.1 Vlan1
neighbor 192.168.254.14 Vlan1
no auto-summary
eigrp stub connected summary
Show ip eigrp topology:
P 192.168.110.0/24, 1 successors, FD is 3072
via 192.168.254.14 (3072/2816), Vlan1
P 10.254.252.0/27, 1 successors, FD is 3072
via 192.168.254.1 (3072/2816), Vlan1
P 192.168.102.4/30, 1 successors, FD is 3072
P 11.11.11.0/24, 1 successors, FD is 3072
P 192.168.100.0/24, 1 successors, FD is 3072
P 192.168.101.0/24, 1 successors, FD is 3072
P 10.31.0.0/24, 1 successors, FD is 3072
P 192.168.44.0/24, 1 successors, FD is 3072
P 192.168.55.0/24, 1 successors, FD is 3072
P 192.168.11.0/24, 1 successors, FD is 2816
via Connected, Vlan40
P 192.168.12.0/24, 1 successors, FD is 2816
via Connected, Vlan41
P 192.168.15.0/24, 1 successors, FD is 3072
Codes: P - Passive, A - Active, U - Update, Q - Query, R - Reply,
r - reply Status, s - sia Status
P 192.168.0.0/23, 1 successors, FD is 3072
P 192.168.2.0/23, 1 successors, FD is 3072
P 192.168.16.0/23, 1 successors, FD is 3072
P 192.168.18.0/23, 1 successors, FD is 3072
P 192.168.254.0/24, 1 successors, FD is 2816
via Connected, Vlan1
P 192.168.200.0/24, 1 successors, FD is 3072
P 192.168.213.0/24, 1 successors, FD is 3072
ozzyosbu1 Tue, 09/16/2008 - 23:41
Hello
its the EIGRP split horizon issue.
both the neighbors are on the same interface
jp
fgasimzade Tue, 09/16/2008 - 23:56
I am afraid I dont understand.
neighbor 192.168.254.14 Vlan1 is Router B
neighbor 192.168.254.1 has nothing to do with my problem, it is complitely another router.
Router C advertises its table to Router B (192.168.254.14). Router B does not advertise it further to Router A
fgasimzade Tue, 09/16/2008 - 23:58
Router A config:
router eigrp 2007
redistribute static
redistribute bgp 65525 metric 10000000 200 255 1 1500 route-map BGP-EIGRP
neighbor 192.168.254.38 Vlan1
neighbor 192.168.254.11 Vlan1
neighbor 192.168.254.46 Vlan1
no auto-summary
ozzyosbu1 Wed, 09/17/2008 - 00:34
ohh..i thought it was router B s config..
and the 192.168.254.1 and 192.168.254.14 are router A and C
could you please post the configs of router B
fgasimzade Wed, 09/17/2008 - 01:20
No, Router A is 192.168.254.1 and Router B is 192.168.254.14, router C is 192.168.254.70
I posted Router B config before, take a look please
ozzyosbu1 Wed, 09/17/2008 - 01:35
hello
u had pasted sh ip protcols
could u give 'sh run | begin router eigrp'..?
if possible pls give the complete config..and one thing eigrp split horizon was a hint for u to look in to what could be your problem, this can be one reason for updates from C not getting passed to A and vice versa.
fgasimzade Wed, 09/17/2008 - 01:38
router eigrp 2007
network 10.254.252.0 0.0.0.31
network 192.168.0.0 0.0.1.255
network 192.168.2.0 0.0.1.255
network 192.168.15.0
network 192.168.16.0 0.0.1.255
network 192.168.18.0 0.0.1.255
network 192.168.55.0
network 192.168.100.0
network 192.168.101.0
network 192.168.106.0
network 192.168.139.0
network 192.168.213.0
neighbor 192.168.254.48 Vlan1
neighbor 192.168.254.70 Vlan1
neighbor 192.168.254.2 Vlan1
neighbor 192.168.1.11 Vlan2
neighbor 192.168.1.254 Vlan2
no auto-summary
I have checked other neighbors and other routers which are being advertised on the same interface - everything works fine
ozzyosbu1 Wed, 09/17/2008 - 01:46
hello
you may need to try this
int vlan 1
no ip split-horizon eigrp 2007
careful, this will bring down your adjacencies.
fgasimzade Wed, 09/17/2008 - 01:53
I have checked another router, which is a neighbor to Router B as well, and networks from Router C are listed in its table. The interface is the same - Vlan1, so the issue is not with split horizon.
Giuseppe Larosa Wed, 09/17/2008 - 02:07
  • Hall of Fame,
    Founding Member
Hello Fuad,
if you do
sh ip route 192.168.11.0 on RouterA
what is the result ?
I wonder if there is any other possible routing source for the prefix with a lower AD that is preferred over the EIGRP route
Hope to help
Giuseppe
Giuseppe Larosa Wed, 09/17/2008 - 03:50
  • Hall of Fame,
    Founding Member
Hello Faud,
this was a basic check.
I see something I don't like in RouterA config:
you say that 192.168.254.1 is routerA if it is so the command
neighbor 192.168.254.1 inside router eigrp 2007 on RouterA is not needed it can't become neighbor of itself.
This can be unrelated with your issue but I would fix it
Hope to help
Giuseppe
fgasimzade Wed, 09/17/2008 - 03:53
No, no ))
Router A is 192.168.254.2
Router 192.168.254.1 is another router and everything is fine with it.
Router C is 192.168.254.70
paul.matthews Wed, 09/17/2008 - 07:11
  • Silver, 250 points or more
All three are in the same subnet, right? In that case router B is right not to tell A about C and vice versa. The problem to me looks like A & C are not becoming neighbours properly. Can they ping each other?
Correct Answer
Richard Burts Wed, 09/17/2008 - 11:12
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Rick
Richard Burts Thu, 09/18/2008 - 05:30
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Fuad
I am glad that my response was helpful in resolving your issue. Thank you for using the rating system to indicate that your issue was resolved (and thanks for the rating). It makes the forum more useful when people can read about an issue and can know that there was a response which did lead to resolution of the issue.
The forum is an excellent place to learn about Cisco networking. I encourage you to continue your participation in the forum.
Rick
fgasimzade Thu, 09/18/2008 - 10:11
Thank you very much! I really appreciate your help! It is not the first time I request help here and I always get a qualified responce
