dragec Tue, 09/16/2008 - 13:20
are you sure that forwarding performance are the same as routing?
Joseph W. Doherty Tue, 09/16/2008 - 15:27
The attachment shows the performance for various switches. Note for the 3560s it lists both the Mpps rate and L3, so I believe the forwarding specification should be both for L2 and L3 on the 3560; assuming you're not doing process switching.
