database.pl not loading in ciscoworks
Answered Question
Sep 16th, 2008
Hey,
i am having problems alot of issues with Ciscowork. I am getting the following messages with the self test.
database.pl
FAIL Self Test Fail to query rmeng.DbVersion, Error: Database server not found (DBD: login failed)
Self Test Fail to query rmeng.SYSTABLE, Error: Database server not found (DBD: login failed)
The version is: LMS3.0.1
Any ideas anyone.
Thanks a million
Anthony.
Correct Answer by Joe Clarke about 8 years 5 months ago
Delete the rmeng.log file. Then run:
NMSROOT\objects\db\win32\dbsrv9 -f NMSROOT\databases\rmeng\rmeng.db
Then restart Daemon Manager, and you should be okay.
Overall Rating: 3.7 (3 ratings)
Joe Clarke Tue, 09/16/2008 - 07:29
Please post the output of the pdshow command. Do you have RME 4.1.1 installed?
Joe Clarke Tue, 09/16/2008 - 08:35
This is what I thought. Please post the list of contents under NMSROOT/databases/rmeng.
Correct Answer
Joe Clarke Tue, 09/16/2008 - 11:47
Anthony O'Reilly Wed, 09/17/2008 - 00:51
Your a genius everything is working like clockwork,
Many many thanks. Much Appreciated.
Anthony
