cme srst mode - no incoming/outgoing calls on Pri
Sep 16th, 2008
I am trying to configure cme in fallback mode. The phones register ok in srst mode but i am unable to make any outgoing calls or receive ddi calls on my Pri.
My DDI range is 8460-8479 & for testing I am trying to get ext 8460 to ring on an ephone-dn of 3306
Can anyone help and tell me if there is something wrong or missing with my dial peers or config?
dial-peer voice 10 pots
description Incoming-DDI
incoming called-number 84[6-7].
direct-inward-dial
port 0/1/1:23
dial-peer voice 20 pots
description Ougoing Calls
destination-pattern 9T
port 0/1/1:23
dial-peer voice 100 voip
description Incoming-Calls
translation-profile outgoing DDI
destination-pattern 84[6-7].
session target ipv4:10.99.254.2
codec g711ulaw
telephony-service
srst mode auto-provision all
srst ephone template 1
srst dn template 1
srst dn line-mode dual
em logout 0:0 0:0 0:0
max-ephones 10
max-dn 15
ip source-address 10.99.254.2 port 2000
no service directed-pickup
system message SRST Mode
time-zone 12
max-conferences 12 gain -6
web admin system name *** password ***
dn-webedit
time-webedit
transfer-system full-consult
create cnf-files version-stamp 7960 Sep 15 2008 23:01:41
voice translation-rule 10
rule 1 /8460/ /3306/
voice translation-profile DDI
translate called 10
aamercado Mon, 09/22/2008 - 22:53
  • Bronze, 100 points or more
"sh isdn status" has multiple frame establish
assume yes above, "debug isdn q931" on incoming call shows setup, and then connect?
csim start 84?? allows you to dial ip phone
csim start 9localdial or 9longdistance allows you to ring those local or long distance numbers
jgross Wed, 09/24/2008 - 00:15
in the Documentation (Configuring SRST Fallback Support), it says you shoud configure
srst mode auto-provision none
non
Does not include information for learned
ephones or learned ephone-dns in the running
configuration. Use this keyword when you want
Cisco Unified CME to provide SRST fallback services for Cisco Unified Communications Manager.
Mabye try this.
Bye
Jo
wbarren Wed, 09/24/2008 - 06:18
Drop the voice tranlation rule and try doing something like this. I have an office setup with CME fall back and found this to be easier
ephone-dn 8 dual-line
number 3306 secondary 8460
acarnegie Wed, 09/24/2008 - 06:25
Thanks for all your responses.
I have actually managed to get this working, it turns out that my config was ok The problem was the way were testing the srst failover. The access lists we were using were only blocking communications between the phones & and CM whereas the Pri mgcp gateway was still able to communicate with the CM. As soon as I completely disconnected the WAN link I was able to make incoming outgoing calls on the pri in srst mode.
