PE router aggregation
Sep 16th, 2008
Hi all,
I'm trying to find a way to aggregate the PE routers to a P router. I've read somewhere that this could be done by putting a LAN switch in the middle and run dot1q trunk to the P router. This would cause the PE to PE traffic on the same switch to hair-pin. Is there a better way to do this?
Thanks in advance,
John
Giuseppe Larosa Tue, 09/16/2008 - 12:26
  • Hall of Fame,
    Founding Member
Hello John,
you can also use a single Vlan and a single IP subnet:
a 10 GE uplink on the L2 switch to the P router and a GE link on each PE and you can aggregate up to 10 PE without oversubscribing in this case PE to PE communication is direct without going through the P router.
MPLS is supported in a LAN environment you are not constrained to point-to-point links.
Be aware that the L2 switch requires specific configuration to deal with MPLS MTU issues.
Hope to help
Giuseppe
jkim@telepacific.com Tue, 09/16/2008 - 13:27
Hi Giuseppe,
thanks for the info. I just realized I failed to mention that the PEs are for MPLS VPN. Will this change anything? The way I understand it, the PEs require a P router for PHP.
Thanks in advance,
John
Giuseppe Larosa Wed, 09/17/2008 - 01:44
  • Hall of Fame,
    Founding Member
Hello John,
MPLS VPN forwarding uses a two levels label stack:
the label that is first after the L2 header (including 802.1Q header if present) is the one chosen by LDP to reach the remote PE loopback.
the second label is the one advertised by the remote PE within vpnv4 address-family.
the second never changes, the first label changes at each router hop.
A special case for two directly connected PE is that instead of a label the remote PE loopback is reached by an implicit null label that is signaled by LDP.
This case is supported the frame will have only one label and that label is the VPNv4 label, the remote PE in receiving the frame understands it is for the right VRF.
So the scenario I've suggested works for MPLS VPN too
Hope to help
Giuseppe
jkim@telepacific.com Wed, 09/17/2008 - 14:35
Giuseppe,
thanks again. Is the implicit-null treated as a label, basically, do I need to add 4 addtional btyes for the implicit null to the MTU? Is there a terminology for this type of setup? I tried to find some docs on this but all I find are P-PE examples and no P-switch-PEs.
John
Giuseppe Larosa Thu, 09/18/2008 - 05:47
  • Hall of Fame,
    Founding Member
Hello John,
the switch needs to support two levels of labels because may be in the future you will need it.
depending on switch platform look for
system mtu
or
enabling jumbo frames
this allow to introduce the switch without effects
Hope to help
Giuseppe
