WIC-1DSU-T1 and 2800 series router
Answered Question
Sep 16th, 2008
Hello everyone. I have a very simple question regarding a 2800 router and WIC-1DSU-T1 cards. The 2800 has HWIC and NM slots, I was working under the assumtion that an HWIC slot would accomadate a WIC card, but the router will not discover these devices and assign them a port as many other routers that I have worked with do. I have tried various IOS with the same results. Any suggestions? Thanks in advance!
Correct Answer by Joseph W. Doherty about 8 years 5 months ago
It's possible you might need to define the WIC card added via the controller command. Don't have access to a 2800 at the moment for an example, but if this is the situation, good chance someone else will provide more info.
Overall Rating: 5 (1 ratings)
Correct Answer
Joseph W. Doherty Tue, 09/16/2008 - 12:12
