Warning message
Cisco 2801 (Voice Gateway + CUE)
Answered Question
Sep 16th, 2008
Hi there,
I got two questions:
1) When I try to login to Cisco 2801 I get the following lines: (I've already changed the default username and password!)
Cisco Router and Security Device Manager (SDM) is installed on this device.
This feature requires the one-time use of the username "cisco"
with the password "cisco". The default username and password have a privilege level of 15.
Please change these publicly known initial credentials using SDM or the IOS CLI.
Here are the Cisco IOS commands.
username <myuser> privilege 15 secret 0 <mypassword>
no username cisco
Replace <myuser> and <mypassword> with the username and password you want to use.
For more information about SDM please follow the instructions in the QUICK START
GUIDE for your router or go to http://www.cisco.com/go/sdm
2) Is there any configuration example to configure CUE on Cisco 2801 (AIM Module)?
Thanks.
Correct Answer by Michael Owuor about 8 years 11 months ago
Hi there,
1. The lines you reference are the default message of the day banner on the ISR routers. To remove the message, go into configuration mode and enter the command "no banner motd"
2. Here's a sample configuration of configuring CME and CUE. The sample configuration should work on your 2801 ISR router. Feel free to give it a try and post here is you run into any issues or need clarification on anything.
http://www.cisco.com/en/US/products/sw/voicesw/ps5520/products_configuration_example09186a008037f2a9.shtml
Hope this helps.
Michael.
Overall Rating: 5 (1 ratings)
Correct Answer
Michael Owuor Tue, 09/16/2008 - 13:04
  • Cisco Employee,
Hi there,
Hope this helps.
Michael.
