MDS 9134 and MS IAS Server Authentication
thefindjack
I have my MDS 9134 switches working with MS IAS server for radius authentication. What I cant do is get into the Admin role with IAS authentication. Does anybody know what parameters I need to pass through IAS to login to the MDS 9134 switches using the "admin" role?
2 Accepted Solutions
inch
Level 3
Level 3
G'day,
Not sure on how to make the IAS server send through the role information but....
You need to send through the cisco-avpair value of 'shell:roles="network-admin"'
where network-admin is the default "admin" role.
Cheers
Andrew
I have attached an MS Word Document showing the approximately 50 steps to complete to set the Cisco-av-pair. Note that you are using custom roles, the role must exist in the MDS, or the user will default to 'network-admin' by design.
Hope this helps,
Mike
inch
Level 3
Level 3
G'day,
Cheers
Andrew
Hope this helps,
Mike
Got it all working, Thanks guys!
