Need help setting up 2 SSID
Sep 16th, 2008
I am trying to setup 2 SSID for my APs. I would like to have one with WPA-PSK and w/tkip encryption and also an open SSID w/no encryption.
I have looked at the online procedure but there seems to be some missing information or items that I just don't get.
I understand having multiple VLANs but I am uncertain what all needs to be done on other hardware (but I can configure it if needed).
Any help would greatly be appreciated.
Thank You
Overall Rating: 3 (1 ratings)
smcltd.com Tue, 09/16/2008 - 12:29
I forgot, the WPA-PSK is the main/default network and dhcp comes from AD. The 2nd open network is for internet access only and dhcp will come from a firewall/router.
jaichauh Tue, 09/16/2008 - 12:35
Please create two VLANs and map them with two different SSID's.
VLAN is require to put two different encryption settings, as encryption is set on the radio not on SSID.
Thus, by creating VLAN we create different sub interfaces on the radio.
Take a look at the following links:
VLAN on Aironet
http://www.cisco.com/en/US/tech/tk722/tk809/technologies_configuration_example09186a0080665ceb.shtml
WPA configuration example:
http://www.cisco.com/en/US/tech/tk722/tk809/technologies_configuration_example09186a008054339e.shtml
-Jai
smcltd.com Thu, 09/18/2008 - 05:59
Thank You, that may be all I need but one last question/clarification. Do I need to do anything with VLANs on the remainder of my network or is this just for the AP.
Currently we do not user VLANS on our network.
Thank You again for your help.
jaichauh Thu, 09/18/2008 - 06:12
This would work.
However, if you want your guest vlan users to go for internet only..(not internal access), then you need to define vlan on the remainder devices and make some policies for these users, so that they can't access the internal network.
-Jai
