VLAN problem with Router 800 model
Sep 16th, 2008
i have a Cisco Router 800 model with a HWIC4ESW modul and a built-in FA0 port. Config is looking as follows (just a snapshot):
interface fa0/0
ip address 10.10.10.1 255.255.255.0
interface fa1
interface fa2
interface fa3
interface fa4
interface vlan 1
ip address 20.20.20.1 255.255.255.0
A host (20.20.20.5) that is connected to fa1 (vlan1) can reach all IPs via ping.
If i try to ping 20.20.20.5 from the router itself or from a host in the 10.10.10.0/24 network, it's not working.
Does anybody know why?
I'm kinda puzzled and would appreciate any help.
Andy
singhsaju Tue, 09/16/2008 - 13:01
  • Silver, 250 points or more
Configure "ip classless" in global mode and then check
Saju
Pls rate helpful posts.
chriswill Wed, 09/17/2008 - 00:33
Are you running a firewall on the host?Trend-micro for example will block pings to the host.If you are running a firewall -turn it off and try your ping from the router again.
Cheers
Chris
