Cisco AP 1252 Antennas 2.4GHz
Answered Question
Sep 16th, 2008
Can somebody tell me if this Acess Point, AIR-LAP1252AG-E-K9, work only with one antenna of 2.4GHz? Because in the configuration tool we are obligated to choose three but i only need one. Do i have to buy the three or can i buy one spare?
Correct Answer by bbxie about 8 years 9 months ago
AIR-LAP1252AG-E-K9 is a 802.11n AP, 11n is based on MIMO which need more than one antenna to gain best performance, so if you want to use 11n by this AP, it is suggested to buy 3 antenna of 2.4GHz.
Overall Rating: 4 (1 ratings)
Correct Answer
bbxie Tue, 09/16/2008 - 15:37
  • Silver, 250 points or more
Scott Fella Tue, 09/16/2008 - 17:09
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 Wireless
If you are looking for an ap with a single antenna, then you should look at the AIR-AP1242-G-A-K9. This ap only has a 2.4GHz radio in which you can turn off diversity and choose which antenna port you will use. Purchase the 1252 if you will buy 3 antennas per radio.... or it is sort of a waste.... in my opinion.
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
