Failover (up but not working???)
Sep 16th, 2008
hi all,
i have configured failover on my 2 ASA but the secondary unit state is : (Secondary - Failed) as shown below. i have configured LAN-Based Failover and stateful failover on the same gig interface.
Could any one assist me please! Thanks...
Updated:
I have found that following information:
Licensed features for this platform:
Maximum Physical Interfaces : Unlimited
Maximum VLANs : 150
Inside Hosts : Unlimited
Failover : Active/Active
VPN-DES : Enabled
VPN-3DES-AES : Enabled
Security Contexts : 2
GTP/GPRS : Disabled
VPN Peers : 750
WebVPN Peers : 2
AnyConnect for Mobile : Disabled
AnyConnect for Linksys phone : Disabled
Advanced Endpoint Assessment : Disabled
UC Proxy Sessions : 2
This platform has an ASA 5520 VPN Plus license.
Does that mean that the license is the problem?
Kindly find attached the output of the show commands: (sh failover & sh failover state)
chris.rae07 Tue, 09/16/2008 - 19:43
Make sure that your failover interfaces are in the up/up state, and that they are not administratively down.
Chris
m.samouka Wed, 09/17/2008 - 01:08
hi, according to the attached show commands the interface is up and the configuration have been successfully replicated on the secondary but the problem is that when i display the status of the failover i found that the status of the Secondary ASA is: Secondary - Failed.
when i enter the commands to switch the ASA from active to standby (no failover active) or on the other ASA (failover active) the process failed.
i'm wondering do i have to contact cisco to change the license on the ASA from Active/Active to Active/Standby as mentioned above?
suschoud Wed, 09/17/2008 - 05:01
  • Gold, 750 points or more
Active/active failover license means that you can setup Active/active as well as Active/standby failover between the units.
Sushil
suschoud Wed, 09/17/2008 - 04:59
The problem here is that the management interfaces :
inside_management
management
have no link between the units.
Issue :
no monitor-interface inside_management
no monitor-interface management
Above commands would effectively stop failover machanism to monitor these two interfaces.
OTHERWISE,CONNECT CABLE BETWEEN THESE INTERFACES JUST AS WITH THE REST OF THE INTERFACES AND ASSIGN ACTIVE/STANDBY IP ADDRESSES ON INTERFACES.
Please rate if helpful
Sushil
