WS-C2960-24TC-L Bug
Sep 16th, 2008
I'm trying to configure the GigabitEthernet interface of the WS-C2960 switch to have a full duplex. Unfortunately, there is no option to configure this neither is the speed of that interface. But these options are present in FastEthernet ports. Is there a bug in SW version 12.2(35)SE5 that explains this abnormality?
Thanks!
glen.grant Tue, 09/16/2008 - 17:05
  • Purple, 4500 points or more
Gig is full duplex by default and generally do not have to hardcode speed and duplex on a gig port it will negotiate it by itself. What you are seeing is by design.
patricia20 Tue, 09/16/2008 - 17:10
Thanks for your reply. That is also my understanding. But how come when I check the status of the interface, the duplex is a-half even though the other port linked to it is configured as full duplex. Any thoughts on this?
Thanks!
patricia20 Wed, 09/17/2008 - 13:21
These details might help, the module inserted in the gig port is GLC-FE-100FX (100BaseFX-FE SFP). And a 100BaseFX on the other link, module type for this is WS-X4124-FX-MT. Do you think this will cause the gig port to be half duplex?
Patricia
jimenez.reuben Thu, 06/28/2012 - 15:19
On the 2960 switch the "dual purpose" uplinks need to be manually configured with "media-type" to be able to set speed/duplex. Default would not allow setting these 2 attributes.
interface GigabitEthernet0/1
switchport mode trunk
media-type rj45
speed 100
duplex full
end
GigabitEthernet0/1 is down, line protocol is down (notconnect)
  Hardware is Gigabit Ethernet, address is
  Description: Uplink to Cat01
  MTU 1500 bytes, BW 10000 Kbit, DLY 1000 usec,
  Keepalive not set
  Full-duplex, 100Mb/s, link type is auto, media type is 10/100/1000BaseTX
http://www.cisco.com/en/US/docs/switches/lan/catalyst2960/software/release/12.2_55_se/configuration/guide/swint.html#wp2219831
Leo Laohoo Thu, 06/28/2012 - 16:00
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 LAN, Wireless
It's not a bug.
You cannot configure the speed and duplex setting of an fibre optic SFP port.  Fibre optic SFP will negotiate to FULL Duplex and 1000Base, period.
amikat Fri, 06/29/2012 - 14:40
  • Silver, 250 points or more
Will you please try to configure "duplex full" interface configuration at the WS-X4124-FX-MT module (other end) as the default setting is "half" for the Cat4000/4500 100-Mbps fiber modules and see if there is any progress.
Best regards,
Antonin
