Cisco ASA 5505 - VPN Configuration
Answered Question
I am trying to setup a VPN connection to allow clients to access the internal network. I have tried using the VPN wizard time & time again but client will connect but can get out to the internet & communicate with any host on the network. I have tried using a dhcp vpn pool in either the 192.x.x.x or the 10.10.1.X network but no luck.
Any comments or suggestions appreciated.
Correct Answer by Marwan ALshawi about 8 years 7 months ago
whats the reason of those commands?
nat (Outside) 0 access-list policyPAT
nat (Outside) 5 10.10.1.0 255.255.255.0
if not spicific reason remove them
and put the foolowing command:
sysopt connection permit-ipsec
in global configuration mode to allow the VPN traffic to bypass interface access lists
good luck
if helpful Rate
Overall Rating: 5 (2 ratings)
Marwan ALshawi Tue, 09/16/2008 - 22:09
  • Purple, 4500 points or more
  • Community Spotlight Award,
    Best Publication, December 2015
to solve ur problem u need split tunneling
with split tunneling u gonna include what should be tunnled over vpn any thing else will go t the normal client setting like defualt gateway for internet
do:
access-list Split_Tunnel_List standard permit 192.168.1.0 255.255.255.0
group-policy VPNT attributes
split-tunnel-policy tunnelspecified
split-tunnel-network-list value Split_Tunnel_List
so only traffic included in ACL Split_Tunnel_List will be included in the VPN tunnel anything else as mentioned will use normal PC seeting
use the following link as a refrence:
http://www.cisco.com/en/US/products/ps6120/products_configuration_example09186a0080702999.shtml
good luck
if helpful rate
Hi Marwan,
The commands that you suggested did work work out great! When I VPN into the ASA, I am able to get out to the internet. The only other issue is that I can not ping or access any of the host on the 192.168.1.0 network. How do I go about doing this? What I want to accomplish is access some network drives on a Microsoft Windows 2003 server.
Thanks in advance.
Manny
Thanks.
Correct Answer
Marwan ALshawi Wed, 09/17/2008 - 21:52
good luck
if helpful Rate
Hi Marwan,
Your suggestions worked out great & am able to access the internet & network drives on the 192.168.1.0 network . I removed the 2 commands & inserted the sysopt connection permit-ipsec command. It worked without the sysopt command but I inserted it anyways because from my understanding it permits IPsec traffic without checking the ACL's?
Anyways thank you so much for all your help.
Manny
