Where is the login button @ 7921 ?
Sep 16th, 2008
Anyone knows where the login button is which used for entering the pin number for making calls if the calls are restricted. I couldnt find it.
bwilmoth Mon, 09/22/2008 - 08:51
  • Silver, 250 points or more
Cisco Unified IP phone is equipped with soft keys for call features and options. soft keys are displayed along the bottom of the LCD screen and are engaged using the corresponding buttons. Soft keys can change according to the state of the phone. “Login” is one of the option in the soft keys.
Login - Provides PIN-controlled access to restricted phone features. Contact your system administrator for additional instructions
Refer to "soft Key Description" section in the below mentioned URL:
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/ip_phones/7921/4.3/english/user/guide/ug_7921.pdf
