Vlan inforamtion
Sep 16th, 2008
Thanks in advance
Hey its my first post so please gentle to me.
I have one server and one L3 switch and in L3 switch i want to make 10 vlans and one port i want to assign as uplink port which should be able to talk with all Vlan...please help?
paul.matthews Tue, 09/16/2008 - 23:41
What will the uplink port be connected to? If another recent Cisco switch, they should default to trunking, which will mean all VLANs will be carried up that port, so another switch will be able to use the same VLANs.
Though reading your comment, and your specific referencs to L3, I wonder if you are trying to use the uplink as a L3 interface?
In that case yo wuld want to do something like
conf t
vlan 10
vlan 11
vlan 12
int vlan 10
ip add
int vlan 11
ip add
int vlan 19
ip add
int fas 0/1 desc L3 uplink
no switch
ip add
obviously you would change VLAN numbers and IP addresses to be appropriate for your network.
