CCME Ringtone problem - Amazing
Sep 16th, 2008
We have CCME with IOS 12.4(13)T . w have this unique issue. I place a call from an IP Phone to outside PSTN user such as a cell phone. then place that call on hold. and then I press the new call softkey and dial the internal extension. but before the internal extension is answered, i end that call and resume the previous call(to cell phone). when i resume the previous call ,i still here the ringtone from the second call which i had ended.
still cant figure out why this issue.
help will be much appreciated
Anonymous (not verified) Mon, 09/22/2008 - 11:50
If you are using SIP protocol, you may try using "supplementary-service sip refer" or remove pots dial-peer with same destination pattern or make SIP trunk dial-peer preference lower than pots dial-peer or you may try using use the supervisory disconnect command in voice-port configuration mode.
The following URL may help you configuring supervisory disconnect command in voice-port:
http://www.cisco.com/en/US/docs/ios/12_3t/voice/command/reference/vrht_s12_ps5207_TSD_Products_Command_Reference_Chapter.html#wp1148143
