Marwan ALshawi Wed, 09/17/2008 - 03:58
  • Purple, 4500 points or more
  • Community Spotlight Award,
    Best Publication, December 2015
it dose
Set Up RADIUS for Authentication
1 Choose Configuration > Remote Access VPN >AAA Setup >AAA Server Groups
> Add. Specify the server group called RADIUS and select RADIUS from the dropdown
menu. Click OK when finished.
2 Click the newly created server group, and under Servers in the Selected Groups, click
Add. Under Interface Name, select inside from the drop-down menu and specify
192.168.1.10 as the IP address of the RADIUS server. Configure a shared key of
SecureMe123, and click OK when finished.
or:
The first step is to set up a RADIUS server for user authentication as follows:
1 Choose Configure > VPN > AAA > AAA Servers and Groups > AAA Servers >
Add. Choose RADIUS as the Server Type and configure 192168.1.10 as its IP
address. Select Configure Key and specify cisco123 as the New Key. Enter cisco123
under Confirm Key. Click OK when finished.
2 Choose Configure > VPN > AAA > AAA Servers and Groups > AAA Server
Groups > Add. Under Group Name, type InternalRADIUS, select RADIUS under
Server Type, and select the previous defined 192.168.1.10 server from the list. Click
OK when finished.
3 Choose Configure > Additional Tasks > AAA and select the Enable AAA option.
Choose Authentication Policies > Login > Add and specify a list name of
SSLVPNRADIUS. Click Add and choose Group radius as the authentication
method. Click OK when finished.
source:
cisco press, SSL Remote Access VPNs, 2008
god luck
if helpful Rate
