Enhanced PAgP
satish_zanjurne Wed, 09/17/2008 - 01:25
Hi Followwing model supports VSS with Enhanced PagP
Model Number Description
WS-C6503-E E-Series 3-slot chassis
WS-C6504-E E-Series 4-slot chassis
WS-C6506 6-slot chassis
WS-C6506-E E-Series 6-slot chassis
WS-C6509 9-slot chassis
WS-C6509-E E-Series 9-slot chassis
WS-C6509-NEB-A 9-slot vertical Network Equipment Building Standards (NEBS) chassis
WS-C6509-V-E E-Series 9-slot vertical chassis
WS-C6513 13-slot chassis
HTH...rate if helpful...
satish_zanjurne Wed, 09/17/2008 - 02:22
Hi Abeid,
I found only above listed devices which supports Enhanced PagP.
It looks like you don't have any of above switches in distribution layer..
But Pagp runs on only above mentioned switches..
Samer Labaky Thu, 10/09/2008 - 07:29
you have to upgrade to version 12.2(46)SE
in order to support Enhanced pagp, once enabled the 3750 will be able to serve as a client for dual-active detection.
eduardo.ramirez Sun, 08/04/2013 - 18:00
Hi Samer I have VSS running on my Choke's Data Center which are connected to my Core’s 65009-E too PAgP is working apparently good on my L3 port-channels but problem is when I have Dual-Active situation for some reason when both get active roll start to have OSPF process ID issues
Any idea or recommendation?
