unsupported device in cna 5.4
amritpatek Tue, 09/23/2008 - 09:10
This AP is supported in CNA. In Topology View, there is no neighbors displayed and I suspect that the option to display neighbors might be disabled (unchecked) in the "Topology Options" dialog. Please check the "Access Points" option in the Topology Options dialog as shown below and see whether the Access Point is displayed.
Hi, thanks for your answer,
look at the attached screenshot, I have all neighbors enabled.
I find out that the 1242G Ap is not supported by CNA. I wonder why!
This aps are supportetd:
Aironet 1200 Series Access Points:
AIR-A12P10B-A-K9, AIR-AP1200, AIR-AP1210, AIR-AP1220,AIR-AP1220A-A-K9, AIR-AP1220A-J-K9, AIR-AP1220B-A-K9, AIR-AP1220B-E-K9, AIR-AP1220B-J-K9, AIR-AP1230A-A-K9, AIR-AP1230A-J-K9, AIR-AP1230A-T-K9, AIR-AP1230B-A-K9, AIR-AP1230B-E-K9, AIR-AP1230B-J-K9, AIR-AP1231G-A-K9, AIR-AP1231G-E-K9, AIR-AP1231G-I-K9, AIR-AP1231G-J-K9, AIR-AP1232AG-A-K9, AIR-AP1232AG-E-K9, AIR-AP1232AG-J-K9, AIR-AP1232AG-N-K9, AIR-AP1232AG-C-K9, AIR-AP1232AG-P-K9, AIR-AP1232AG-S-K9, AIR-AP1232AG-T-K9, AIR-AP1242AG-A-K9, AIR-AP1242AG-E-K9, AIR-AP1242AG-I-K9, AIR-AP1242AG-J-K9, AIR-AP1242AG-N-K9, AIR-AP1242AG-C-K9, AIR-AP1242AG-P-K9, AIR-AP1242AG-S-K9, AIR-AP1242AG-T-K9, AIR-AP1242AG-K-K9
Any ideas.
