09-17-2008 03:27 AM
I have configured a 3560 (122-44 IP Services) switch to communicate WCCP with an WAE-612 v4.1. However the devices don't form WCCP server-client relation with each other.
When I enable "debug wccp all" on the WAE: It complains with:
"2008 Sep 17 13:54:49 CCI-WC-NC-01 wccp: %WAAS-DDBG-7-899998: ISU assignment capability 2
2008 Sep 17 13:54:49 CCI-WC-NC-01 wccp: %WAAS-DDBG-7-899998: wccp2.c:3169:
2008 Sep 17 13:54:49 CCI-WC-NC-01 wccp: %WAAS-DDBG-7-899998: Router cannot support configured capability for assignment method."
WAE-612 is directly connected to the switch through a vlan. I tried GRE and L2 forwarding methods.
Solved! Go to Solution.
09-17-2008 04:56 AM
3560/3750 should use the following configurations guidelines...
1. Ingress interception (redirect out isn't supported.
2. Layer 2 redirect
3. Layer 2 return is supported (and preferred)
4. Mask assign (default of hashing is not supported)
5. WAE must be L2 adjacent, no L3 hops.
Hope that helps,
Dan
09-17-2008 04:15 AM
Can you post the configuration for the wccp router-list on the wae and the wccp configurations from the switch? It look like you are using mask assignment when you should be using hash or vice versa.
09-17-2008 04:56 AM
the wae config and wccp output:
CCI-WC-NC-01#sh run | i wccp
wccp router-list 8 192.168.192.33
wccp tcp-promiscuous router-list-num 8 l2-redirect assign-method-strict l2-return
wccp version 2
CCI-WC-NC-01#sh wccp router
Router Information for Service: TCP Promiscuous 61
Routers Configured and Seeing this Wide Area Engine(0)
-NONE-
Routers not Seeing this Wide Area Engine
192.168.192.33
Routers Notified of but not Configured
-NONE-
Multicast Addresses Configured
-NONE-
Router Information for Service: TCP Promiscuous 62
-NONE-
192.168.192.33
-NONE-
-NONE-
3560 config and wccp outputs:
CCI-SW-NC-BB-01#sh run | i ip wccp
ip wccp 61 redirect-list 101
ip wccp 62 redirect-list 102
CCI-SW-NC-BB-01#sh ip wccp
Global WCCP information:
Router information:
Router Identifier: 192.168.192.254
Protocol Version: 2.0
Service Identifier: 61
Number of Service Group Clients: 0
Number of Service Group Routers: 0
Total Packets s/w Redirected: 0
Process: 0
CEF: 0
Redirect access-list: 101
Total Packets Denied Redirect: 0
Total Packets Unassigned: 0
Group access-list: -none-
Total Messages Denied to Group: 0
Total Authentication failures: 0
Total Bypassed Packets Received: 0
Service Identifier: 62
Process: 0
CEF: 0
Redirect access-list: 102
thanks
09-17-2008 04:58 AM
you need to add the mask-assign statement to your WAE config. The 3650 doesn't support hash-assign (default). See my other response.
Dan
09-17-2008 04:56 AM
2. Layer 2 redirect
Hope that helps,
Dan
09-17-2008 06:03 AM
Thanks Dan,
Mask assignment solved my problem.
Bulent
