How to disable Smartcard Removal Feature
Sep 17th, 2008
Posted by: dromer
Sep 16, 2008, 4:41am PST
we`re using VPN Client 5.0.03.0560 connecting to VPN Concentrator 3015 and ACS 4.1(1) Build 23 Patch 4 with Smartcard Authentication. How can we disable the "Smartcard Removal Feature", so that VPN connections don`t tear down if the card is removed ?
If found some documentations for the ASA but not for Concentrator/ACS.
Many thanks
Juergen
sadbulali Tue, 09/23/2008 - 09:03
we can disable the "Smartcard Removal Feature" using the smartcard-removal-disconnect command:
group-policy name attributes
[no] smartcard-removal-disconnect {enable | disable}
Disabling this option configures the Client to leave existing tunnels connected when a SmartCard is removed. Enabling this option configures the Client to disconnect existing tunnels when a SmartCard is removed. This option is enabled by default. The no form of the command removes the command from the configuration and reverts to the default value
lutscho Wed, 09/24/2008 - 03:17
you can disable it at VPN Concentrator 30XX ?
How ?
Thanks !
Juergen
