How can I optimize the ECC variables?
Sep 17th, 2008
Hi, I have a huge problem about defining the ECC variables.
I have ICM 7.2 + CVP 4.1 + Outbound Option environment and I defined the all ECC variables as configuration guide said. The problem is I have to define extra ECC variables for my applications and my workflows but I cant. Because as you know the system has limitations with 2000 bytes and the default connfiguration uses nearly 1800 Bytes. I need 400 byte extra. I know I can use peripheral variables but I dont want this.
so the question is how can I optimize the variables. Can delete some of them or can I reduce their sizes?
