1st & 2nd phase proposals
Sep 17th, 2008
Hi ive got a cisco 877 and a netscreen 5gt.
The netscreen is configured as the hub with phase 1 pre-g2-3des-sha, and phase 2 set to nopfs-esp-3des-md5. How would I configure my transform sets on the cisco 877? Can anyone help?
Istvan_Rabai Wed, 09/17/2008 - 09:21
Hi Colin,
Phase 1:
crypto isakmp policy 10
encryption 3des
hash sha
authentication pre-share
group 2
Phase 2:
crypto ipsec transform-set MYTRANS esp-3des esp-md5-hmac
Cheers:
Istvan
crmljc1976 Fri, 09/26/2008 - 01:02
it wont let me enter hash sha under crypto isakmp policy 10. Why is that?
Istvan_Rabai Fri, 09/26/2008 - 08:59
Probably your IOS image doesn't have this feature.
Try using "hash md5" and if it works, configure netscreen the same way.
Cheers:
Istvan
ajagadee Fri, 09/26/2008 - 10:42
SHA is the default hashing algorithm for ISAKMP policy and that is why you are probably not seeing it in the running configuration.
For example, I have SHA Configured under ISAKMP Policy 10 on my router but it does not show in the running configuration.
encr 3des
group 2
But, if I run the command "Show crypto ISAKMP Policy", I can see it in there.
R16-2821c#sh crypto isakmp policy
Global IKE policy
Protection suite of priority 10
encryption algorithm: Three key triple DES
hash algorithm: Secure Hash Standard
authentication method: Pre-Shared Key
Diffie-Hellman group: #2 (1024 bit)
lifetime: 86400 seconds, no volume limit
Protection suite of priority 20
Arul
** Please rate all helpful posts **
crmljc1976 Wed, 10/01/2008 - 00:51
hi keep getting phase 2 no policy exists for proxy id received on the netscreen ,all phase 1 and 2 configured correctly. Has anyone got any experience programming netscreen5gt and cisco 877 VPNs. Thanks
