Non Cisco switches
Sep 17th, 2008
when using non cisco switches for Ip phones
such as HP or 3com, I assume you can have a voice vlan as well as a data vlan on the same port, like the cisco switches?
Do the phones register o.k as if they were
cisco switch?
Overall Rating: 5 (3 ratings)
a.gooding Wed, 09/17/2008 - 08:03
  • Bronze, 100 points or more
from my very limited experience with non-cisco switches and this, the phones do register fine however you need to manually set the vlans on the phones and there is no CDP on these non-cisco switches.
Note: im assuming you are using two vlans and using switchport voice vlan "X"
slongewa Wed, 09/17/2008 - 11:52
The above post is correct. All the QoS, etc, etc will have to be setup manually as well as hard-coding the voice VLAN on the phone becuase you will not have the CDP information being passed back and forth to establish the Voice VLAN automatically.
Hope this helps,
Steve
