09-17-2008 06:11 AM - edited 03-15-2019 01:20 PM
Hi!
When I configure an SD button the phone shows a gray color line. The client as an image background and he would like to have only the SD Label but not the gray line. How can I change this?
Ana
Solved! Go to Solution.
09-17-2008 01:26 PM
sorry, that's WAD (working as designed) the behavior cannot be changed, they'll have to live with that.
java
if this helps, please rate
09-17-2008 01:26 PM
java
09-18-2008 01:36 AM
OK. Thanks. What about the grey that it fills between lines? Is it also unchangeable?
Ana
