In CUCM 6/7, is it possible to bring up a primary node
Answered Question
Sep 17th, 2008
in a cluster when the primary node(publisher) fails without restoring via DRS?
Just wondering if is it possible at all?
Let's say by using some dbreplication command to replicate the subscriber's data to rebuilt the publisher's database.
Correct Answer by rob.huffman about 8 years 4 months ago
Hi Kinwai,
CCM 6.x and 7.x has the same design considerations as before when it comes to the Single Publisher with multiple Subscriber setup. My understanding is that Cisco is working on a method to promote a Sub to Pub for Disaster recovery purposes, but this has not yet been released. Soon I hope :)
Hope this helps!
Rob
Overall Rating: 5 (1 ratings)
Correct Answer
rob.huffman Wed, 09/17/2008 - 08:20
Hi Kinwai,
Hope this helps!
Rob
kinwai Wed, 09/17/2008 - 08:27
Hi Rob,
thanks a lot! Hopefully it will be possible soon!
I'm trying out the new CUCM 7 beta from cisco, i found a lot of new commands especially in "utils dbreplication",so just wondering if it's possible now.
Cheers,
kinwai
