Phase 1 issues.. Can't see with my Eyes..
Sep 17th, 2008
I have been staring at this config now for the better part of the night an into this morning. I have ran all the basic debugs and my config is failing on phase 1. I have included the config on the router for the VPN clients. Can some one tell me what I am missing.
Frank
Istvan_Rabai Wed, 09/17/2008 - 09:44
  • Gold, 750 points or more
Hi Frank,
Running through your config I found one possible fault, acl 102:
I think it should be:
"access-list 102 permit ip 192.168.0.0 0.0.0.255 any" if you want the 192.168.0.0/24 network to be injected into the routing tables of vpn clients.
In addition, you should specify the netmask for the 365vpn group under the
"crypto isakmp client configuration group 365vpn"
command, as the "ip local pool" command does not specify one.
E.g: "netmask 255.255.255.240"
Cheers:
Istvan
