Call forwarding failed only for 800 number
Sep 17th, 2008
We have a Unity vm server at the data center. It is assign by PRI which has both 1800 number and a local number(416-123-4567). I have configured the SRST gateway and the call forwading for VM.
When users dial the 1800 number directly, it works fine. But when the call is forwarded to 1800 number, user hears 'The call cannot be routed'. But if I change the 1800 number to the 14161234567, both directly and forwarded call are working fine.
SO I just wondering what is the different from the Telco's perspective?
shabali52 Wed, 09/17/2008 - 10:37
Under unity Restriction table, you have make an exception to allow forwarded calls to 1800 numbers. The pattern should look like 91800???????
richard.gu Wed, 09/17/2008 - 11:35
It is not on the unity.
Basically, when the gateway is in srst mode, external user call the extension and get forward (no answer) to the 1800 number based on the srst configuration on the gateway.
shabali52 Wed, 09/17/2008 - 11:43
I am sorry, I took completely to the wrong path.
