09-17-2008 10:50 AM - edited 03-14-2019 02:54 AM
Is is possible to get "Dial number as Entered checkbox" Ticked always(by registry change on the CAD PC or by any other method?),so that we don't have to tick it everytime while making a outgoing call.
09-17-2008 11:45 AM
This would be beneficial, however if I remember correctly, once you set it it should remember your setting.
david
09-18-2008 04:26 AM
It will check this box and keep it checked - it will be greyed out - if you use CAD Admin and change the Work Flow Config - Dial Strings and change to "Variable Length Dial Strings" so there are auto no inserts of PBX access code (say 9) or long distance access code (say 1).
The CAD thing is very North American-centric. You need to stop that.
Geoff
