ASA Logs
Answered Question
Sep 17th, 2008
I'm trying view the traffic logs. Can someone assist me with the command?
Correct Answer by suschoud about 8 years 4 months ago
Here are the steps for setting up the syslog server.
First you would need to install a syslog server software on one of the computers. You may
download one of the popular kiwisyslog server from
http://www.kiwisyslog.com/software_downloads.htm . It is listed as Kiwi
Syslog Daemon and latest version is 8.2.8. You may download standard edition that runs as
a program.
Once the syslog server is installed you will then need to login into the ASA in
configuration terminal mode and enter the following commands.
logging host [in_if_name] ip_address
(example: logging host inside 1.2.3.4
We are assuming syslog server is installed on computer with IP address 1.2.3.4 in the
inside network.)
logging timestamp
logging trap 4
logging on
These commands will enable the ASA to start sending syslog messages to the syslog server.
For more information on logging commands you may refer to this URL:
http://www.cisco.com/en/US/products/sw/secursw/ps2120/products_command_refer
ence_chapter09186a008010578b.html#1028090
Trap levels
.0-emergencies-System unusable messages
.1-alerts-Take immediate action
.2-critical-Critical condition
.3-errors-Error message
.4-warnings-Warning message
.5-notifications-Normal but significant condition
.6-informational-Information message
.7-debugging-Debug messages and log FTP commands and WWW URLs
Do rate helpful posts.
Sushil
Overall Rating: 5 (1 ratings)
Correct Answer
suschoud Wed, 09/17/2008 - 12:12
a program.
inside network.)
logging timestamp
logging trap 4
logging on
Trap levels
Sushil
