Enabling SSH
Sep 17th, 2008
Are the following commands enough to configure ssh for allowing access from outside for full access to enable mode?
ssh outside
cryto key generate rsa modulus 1024
aaa authentication ssh console LOCAL
username (username) password (password) privilege 15
Istvan_Rabai Wed, 09/17/2008 - 20:26
Hi Patrick,
For ssh access through the vty lines you could add the following:
conf t
aaa authentication login SSH_LOGIN local
aaa authorization exec SSH_ACCESS local
line vty 0 4
login authentication SSH_LOGIN
transport input ssh
Farrukh Haroon Thu, 09/18/2008 - 00:28
Assuming this is a Cisco firewall you are talking about, these commands should suffice.
However the ANY ANY access on the outside is not really a good security practice. But it will work!
