Route Leaking from Multiple VRF's into the Global RT Dynamically
Sep 17th, 2008
I have looked through quite a few posts however am not able to confirm if this is possible or not. I have multiple VRF's configured and I would like to have all the routes from all the vrf's be leaked into the Global RT. Since there are multiple VRF's using static routes is not an option. Is there a way to dynamically exchange the routes. I am using only VRF-Lite and plan to use BGP and RIP as the vrf-aware routing protocols. I did read a post where it was mentioned to connect a back-to-back cable with one end in a VRF and the other in the global RT however am not comfortable doing this as this. The device being used is a 6500. Thanks for your help.
danail-petrov Thu, 09/18/2008 - 03:17
In few words - yes, it's possible. I will show you how to achieve this.
Let's say that you have two customers, Customer A and Customer B therefore you need two VRFs for each of them. For instance:
ip vrf CustomerA
rd 65500:10
route-target export 65500:10
route-target import 65500:20
ip vrf CustomerB
rd 65500:20
route-target export 65500:20
route-target import 65500:10
Are you following me ...
router bgp 200
no synchronization
bgp log-neighbor-changes
no auto-summary
address-family ipv4 vrf CustomerA
no synchronization
network 172.16.10.0 mask 255.255.255.0
exit-address-family
address-family ipv4 vrf CustomerB
no synchronization
network 172.16.115.0 mask 255.255.255.0
exit-address-family
Let's say that we have two vlan interfaces to each of our customers:
interface GigabitEthernet0/0.10
encapsulation dot1q 10
ip vrf forwarding CustomerA
ip address 172.16.10.1 255.255.255.0
interface GigabitEthernet0/0.20
encapsulation dot1q 20
ip vrf forwarding CustomerB
ip address 172.16.115.1 255.255.255.0
That is enough. It works like a charm. Now the CustomerA is able to reach Customer's B network 172.16.115.0/24 (Sometime you must execute the clear ip bgp * in order to get it work)
Here is some output:
Router#show ip bgp vpnv4 all
BGP table version is 7, local router ID is 10.0.0.1
Status codes: s suppressed, d damped, h history, * valid, > best, i - internal,
r RIB-failure, S Stale
Origin codes: i - IGP, e - EGP, ? - incomplete
Network Next Hop Metric LocPrf Weight Path
Route Distinguisher: 65500:10 (default for vrf CustomerA)
*> 172.16.10.0/24 0.0.0.0 0 32768 i
*> 172.16.115.0/24 0.0.0.0 0 32768 i
Route Distinguisher: 65500:20 (default for vrf CustomerB)
Router#show ip route vrf CustomerA 172.16.115.0
Routing entry for 172.16.115.0/24
Known via "bgp 200", distance 20, metric 0 (connected), type external
Routing Descriptor Blocks:
* directly connected, via GigabitEthernet0/0.10
Route metric is 0, traffic share count is 1
AS Hops 0
Router#show ip route vrf CustomerB 172.16.10.0
Routing entry for 172.16.10.0/24
* directly connected, via GigabitEthernet0/0.20
AS Hops 0
Router#ping vrf CustomerA 172.16.10.1 source Gi0/1.20
Sending 5, 100-byte ICMP Echos to 172.16.10.1, timeout is 2 seconds:
Packet sent with a source address of 172.16.115.1
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/1/1 ms
Hope it helps ;-)
vdadlaney Thu, 09/18/2008 - 05:37
Hi Danail,
Thank you for responding. However I have no problems with talking between VRF's. I would like to know if it is possible to get the various routes in the VRFs into the Global Routing table dynamically. Please note I mean the Global Routing table. Per your config above you are using the RT to import the routes between A and B but how would I get the routes from A and B into the Global Routing table Dynamically. Using static vrf routes with the global keyword is not an option for me due to the number of VRF's that I have and the number of routes in each VRF. Thx
Deniz AYDIN Thu, 09/18/2008 - 06:19
I have also this kind of problem. I have talked with cisco tac, and as far as ı know there is no way to do this dynamically.
Harold Ritter Wed, 09/24/2008 - 17:52
  • Cisco Employee,
Vikram,
There is a feature that allows to dynamically import routes from the GRT into a VRF but not the other way around.
To dynamically advertise routes from the VRF to the GRT, you could configure a hairpin between the VRF and the GRT and run a BGP session between the two.
amitbatra Tue, 10/14/2008 - 17:23
Hi ,
Could you please share the configuration of hairpin.
may be a sample.
regards
amitbatra Tue, 10/21/2008 - 17:27
Hi ,
i know how to create a GRE tunnel and run routing protocol on the top of it to exchange routes.
I dont know whether they all that Hairpin.
if that is the case i can share that information with you
I do not think this is what I am looking for.
I have two "NAT" PE routers at the edge of our MPLS network. These default route to two firewalls in the global routing table on two separate networks, thus creating four possible routes to the Internet.
I was looking to advertise a default route into my VRF's dynamically instead of having to add 4 statically weighted routes.
amitbatra Wed, 10/22/2008 - 12:24
Send me ur config and in detail what you wanna achieve. i will see what i can do for u.
regards
amit
